Cisco Works Cisco View Updating Packages Error
DELL ACORD
Following packages cannot be installed
Package Reason
Cat6000(7.0) major versions are incompatible.Required version 7.10 for Cat6000 package
Can anyone explain what this means and how do I fix this so that I can upgrade to get those unsupported line card errors on Cisco View?
rmushtaq
Level 8
Level 8
I think you also need to update the CatQDM package first, try it to see if it helps.
