Cisco works (Lan Management Solution)
khalid166
Hi All,
       I am running with LMS 3.2. I have added all the required devices to the LMS and its working fine and taking the backup of Start-up and running configuration as well as vlan information from the devices. My question is that can i configure LMS to take the Show tech-support of all the devices?
Regards.
Khalid.
Vinod Arya
This is possible via scheduling a job in RME for NetShow. You can have the output of any show commands including show tech support.
Network show (NetShow) commands represent a set of read-only commands. These are primarily, show commands that you can run on devices that are managed in RME.
For more details please check Using NetShow Commands section on User guide.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Vinod Arya
-Thanks
Vinod
Hi Vinod,
            Thanks for your support its working fine now.
