Cisco Works LMS 4.0 doesn´t start
MarioLieb
Hello All
i have big trouble with me LMS 4.0 installation. I did an Upgrade from LMS 3.2 to LMS 4.0. After that the Works was running without any problems. After some days i´d tried to login on the LMS and it told me something like my lincens where corrupt or so. I´d tried to start the CiscoWorks Demon Manger but he didn´t start. OK after some investigation at the i-net i decided to perform a clean installation of the Server an Cisco Works.
So after i do thes i´d perform a restore of my old Data from LMS 3.2. Now i investicated that my ANI Server Falied to start. OK than i tried to restart the Works Demon ... f... and what will happend ?!?!?! The demon doesn´t start. Can someone help me ?!?! Please i will not perform a new istallation again.
C:\Windows\system32>net start crmdmgtd
The CiscoWorks Daemon Manager service is starting.
The CiscoWorks Daemon Manager service could not be started.
The service did not report an error.
More help is available by typing NET HELPMSG 3534.
Mario
Hi i have an update for this issues ... After i´d tried to start all Works- Services be hand ... all Services will start execpt the deamon ... When i loged in i get messages "License Server/Deamon Manager is down. Please  check license.log for more information."
Thats the same situtaion befor the new installation.
16 Replies 16
Hi Afroj
i´d just have an update for you and maybe for Martin. I´d checked the services and investigate that the ANIDatabase Engine
was not stoped. After i stoped the service "by Hand". I tried to reinalize the Database and see ... IT WORKS ...
D:\CiscoWorks\CSCOpx\bin>perl.exe dbRestoreOrig.pl dsn=ani dmprefix=ANI
WARNING: Existing contents of ani database will be lost.
Do you want to continue [y/n]?y
INFO: Starting the DataBase
    Starting database engine aniEng
INFO: Process created
INFO: Started the Database engine : aniEng Retry 0
INFO: Started the Database engine : aniEng Retry 1
INFO: Started the Database engine : aniEng Retry 2
INFO: Started the Database engine : aniEng Retry 3
INFO: Started the Database engine : aniEng Retry 4
INFO: Started the Database engine : aniEng Retry 5
INFO: Started the Database engine : aniEng Retry 6
INFO: Started the Database engine : aniEng Retry 7
INFO: Started the Database engine : aniEng Retry 8
INFO: Started the Database engine : aniEng Retry 9
INFO: Getting message
INFO: Connect the database dsn=ani
INFO: Connected the Database
INFO: Command Executed
INFO: Connecting the Database ani
INFO: Company=Cisco Systems;Application=NMTG;Signature=010fa55157edb8e14d818eb4f
e3db41447146f1571g32125eb777a87cbf8b29a954f559d4221b792ff8
INFO: Preparing AUTH cmd
INFO: AUTH Executed
INFO: AUTH cmd finished
INFO: Stopping the Database engine ani
    Stopping database engine aniEng
INFO: File not exists.SQL Anywhere Command File Hiding Utility Version 10.0.1.40
51
INFO: Database [ani] authenticated successfully.
ani database initialization is completed.
D:\CiscoWorks\CSCOpx\bin>pdshow ANIServer
        Process= ANIServer
        State  = Running with busy flag set
        Pid    = 11136
        RC     = 0
        Signo  = 0
        Start  = 8/22/2011 1:01:29 PM
        Stop   = Not applicable
        Core   = Not applicable
        Info   = ANIServer started.
Many Thanks for your help ...
Mario
Hi Mario,
Thanks for the update.. Great News
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
