Cisco WS-c3850-24T,SW Vers 03.06.06e Port (Interface) bandwidth limit
c18.oct
I want to use bandwidth shaping in my cisco switch WS-c3850-24T,SW Version 03.06.06e. There is no option available for bandwidth shaping/limiting for a specific interface as like shaping, rate-limit, srr-queue. Please help
you need to use QoS for bandwidth shape, limits and ratings. check below guide for 3850 switches.
https://www.cisco.com/en/US/docs/switches/lan/catalyst3850/software/release/3.2_0_se/multibook/configuration_guide/b_consolidated_config_guide_3850_chapter_010000.html
rate this and mark as answer, if this solved your issue
Good luck
KB
