Bookmark
Subscribe
3730
cisco WS-C6509-E OID for Virtual Switching System
raindrop18
The OID I am using  for module index 6509-E family is not working on 6509 Virtual Switching System(VSS).I have used "1.3.6.1.4.1.9.5.1.3.1.1.1" for single 6509-E configuration. is anyone know OID for module index on VSS environment. Thanks, Paul
5 Replies 5
raindrop18
anyone has any solution for this question.
VSS does not support the use of the CISCO-STACK-MIB for returning the information you seek. You would likely have to revert to using the
entPhysicalDescr / .1.3.6.1.2.1.47.1.1.1.1.2 or entPhysicalName / 1.3.6.1.2.1.47.1.1.1.1.7. and indexing from the Entity-Mib.
Partial Tree from the ENTITY-MIB:
+--entPhysicalEntry(1) detail
   +-- ---- Integer   entPhysicalIndex(1)
   |        Textual Convention: PhysicalIndex
   |        Range: 1..2147483647
   +-- -R-- String    entPhysicalDescr(2)
   |        Textual Convention: SnmpAdminString
   |        Size: 0..255
   +-- -R-- ObjID     entPhysicalVendorType(3)
   |        Textual Convention: AutonomousType
   +-- -R-- Integer   entPhysicalContainedIn(4)
   |        Range: 0..2147483647
   +-- -R-- EnumVal   entPhysicalClass(5)
   |        Textual Convention: PhysicalClass
   |        Values: other(1), unknown(2), chassis(3), backplane(4), container(5), powerSupply(6), fan(7), sensor(8), module(9), port(10), stack(11)
   +-- -R-- Integer   entPhysicalParentRelPos(6)
   |        Range: -1..2147483647
   +-- -R-- String    entPhysicalName(7)
   |        Size: 0..255
Then you can use that
same index to relate cefcModuleTable (CISCO-ENTITY-FRU-CONTROL-MIB) for module specific information such as status, etc. Partial tree view from that MIB:
.1.3.6.1.4.1.9.9.117.1.2
+--cefcModuleTable(1) detail
   +--cefcModuleEntry(1) detail
   |  +-- -RW- EnumVal   cefcModuleAdminStatus(1)
   |  |        Textual Convention: ModuleAdminType
   |  |        Values: enabled(1), disabled(2), reset(3), outOfServiceAdmin(4)
   |  +-- -R-- EnumVal   cefcModuleOperStatus(2)
   |  |        Textual Convention: ModuleOperType
   |  |        Values: unknown(1), ok(2), disabled(3), okButDiagFailed(4), boot(5), selfTest(6), failed(7), missing(8), mismatchWithParent(9), mismatchConfig(10), diagFailed(11), dormant(12), outOfServiceAdmin(13), outOfServiceEnvTemp(14), poweredDown(15), poweredUp(16), powerDenied(17), powerCycled(18), okButPowerOverWarning(19), okButPowerOverCritical(20), syncInProgress(21)
   |  +-- -R-- EnumVal   cefcModuleResetReason(3)
   |  |        Textual Convention: ModuleResetReasonType
   |  |        Values: unknown(1), powerUp(2), parityError(3), clearConfigReset(4), manualReset(5), watchDogTimeoutReset(6), resourceOverflowReset(7), missingTaskReset(8), lowVoltageReset(9), controllerReset(10), systemReset(11), switchoverReset(12), upgradeReset(13), downgradeReset(14), cacheErrorReset(15), deviceDriverReset(16), softwareExceptionReset(17), restoreConfigReset(18), abortRevReset(19), burnBootReset(20), standbyCdHealthierReset(21), nonNativeConfigClearReset(22), memoryProtectionErrorReset(23)
   |  +-- -R-- Timeticks cefcModuleStatusLastChangeTime(4)
   |  |        Textual Convention: TimeStamp
   |  +-- -R-- Timeticks cefcModuleLastClearConfigTime(5)
   |  +-- -R-- String    cefcModuleResetReasonDescription(6)
   |  |        Textual Convention: DisplayString
   |  |        Size: 0..255
   |  +-- -R-- String    cefcModuleStateChangeReasonDescr(7)
   |  |        Size: 0..255
   |  +-- -R-- UInteger  cefcModuleUpTime(8)
   |  |        Textual Convention: FRUTimeSeconds
Hope that helps,
Cary
thank you so very much for your response. would you mind if you can give me an example. my understanding is i have to include this mib on the script to get index? I am actually looking for a serial number of each module. each chassis currently has 9 module which is total 18. so i need a serial number of all 18 modules. can I get that by using your method? thanks again!
Can you get me the output from the following:
snmpwalk -v2c -c .1.3.6.1.2.1.47.1.1.1
You can send that directly to my email address at ccube@cisco.com
Cary
thanks Cary, I have sent you the snmp out put via email. Eli
