ciscoview not working on 2948
adamtroxel
I am having a problem getting the interface for cisoview to come up. It tries to go to the page and comes back with a page all grey with the word undefined in the upper left. Not sure where to go from here... Please help?
I have the switch configured correctly.
Console> (enable) sh ip http
HTTP Information
HTTP server: enabled
HTTP port: 9999
Web Interface: Supported
Web Interface version(s):
Engine: 5.3.4 ADP device: Cat4000 ADP Version: 5.0 ADK: 49
and
bootflash
1 4808128 Jul 25 2008 20:18:05 cat4000-k8.8-4-11-GLX.bin
2 2466066 Jul 25 2008 20:30:24 cat4000-cv.8-4-1-GLX.bin
Joe Clarke
Please post a screenshot of the problem as well as the version of Java you have loaded on your client. It would also be helpful to see the Java plug-in console.
Im running java 1.6 on os x 10.5
error console is empty.
i get the same response from ubuntu heron as well.
browsers tried: safari, firefox.
That will not work. You must run this On Internet Explorer or Netscape with Java Plug-in 1.3.1. Note that the CiscoView ADP module is very old, and no longer supported. Instead, it is recommended to use host-based CiscoView as part of CiscoWorks LAN Management Solution.
See http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a0080094156.shtml for more on using the CiscoView ADP.
