Ciscoworks 4.0, netconfig job, add instance problem
pd.politiet.no
I'm trying to make an adhoc job to some devices in ciscoworks.  I select netconfig jobs, select the devices I want to do a change to, and then select add instance, I get a new browser window saying loading and nothing more happens.
I cannot create the config lines I want to perform to my switches.  I just want to change the vtp domain name to the switches, but cannot do this due to the blank browser window saying loading.
Anyone know anything about this?
Br
Geir
16 Replies 16
At this point, TAC will need to provide you a valid SharedNetconfigIOS package at the very least.  However, I recommend they give you a complete LMS Config and Inventory package repository just to be on the safe side.
Just want to give you en update to this problem.
I opened a TAC, and while waiting for the answer a couple of days ago there was an update to LMS.  LMS 4.0.1 was downloaded and installed.
Now I can use the netconfig jobs again.
Br
Geir
