ciscoworks 4.2 - dfm email issue
secureIT
Level 4
Level 4
Hi Cisco Team,
Dfm email alerts are not coming though it was configured properly.
Did a wireshark pcap and below is the info taken from wireshark.
Command: MAIL FROM:<itreports.alerts@mycompany.com>\r\n
Command: RCPT TO:<network.support@mycompany.com>\r\n
Response: 550 5.7.1 Unable to relay for network.support@mycompany.com\r\n
Response code: Requested action not taken: mailbox unavailable (550)
Response parameter: 5.7.1 Unable to relay for network.support@mycompany.com
Im able to telnet to smtp server on port 25.
ciscoworks ip and smtp server ip are in the same pvt ip range.
Can you pls help.
19 Replies 19
pls find the attached screenshot of regdaemon.xml.
i have verified that the same smtp server name was configured in regdaemon.xml and defaultsmtp server.
any other details you require ?
Attaching smtp.log & screenshot of regdaemon
Hi Rajesh,
Type:Daily
[ Fri Jan 24 12:00:25 IST 2014 ] INFO   [Util : sendMail]  : sendMail()  - Ends
[ Fri Jan 24 12:05:03 IST 2014 ] INFO   [Util : sendMail]  : sendMail()  - Starts
[ Fri Jan 24 12:05:03 IST 2014 ] INFO   [Util : sendMail]  : SMTP Server:hm02sql01.xyz.com
[ Fri Jan 24 12:05:03 IST 2014 ] INFO   [Util : sendMail]  : Date:Fri, 24 Jan 2014 12:05:03 +0530
[ Fri Jan 24 12:05:03 IST 2014 ] INFO   [Util : sendMail]  : From ID:network.support@xyz.com
[ Fri Jan 24 12:05:03 IST 2014 ] INFO   [Util : sendMail]  : To ID:
[ Fri Jan 24 12:05:03 IST 2014 ] INFO   [Util : sendMail]  : Subject:Job Id:1004.277, Status:Failed(25), Application:SysInvPoller, Run Type:Daily
[ Fri Jan 24 12:05:03 IST 2014 ] INFO   [Util : sendMail]  : sendMail()  - Ends
This seems to show that the smtp server is trying to push the mail.
Please check if the smtp server host name is correct in the log.
Syed Khalid
secureIT
Level 4
Level 4
Hi syed
The default smtp server name, smtp server hostname and log's hostname are the same 'hm02sql01.xyz.com'
What else needs to be checked.
Sent from Cisco Technical Support Android App
secureIT
Level 4
Level 4
Hi Syed
Can you pls help me to proceed this..
As LMS is able to send the email notification according to log. Are you sure your SMTP Server is entertaining it properly?
Can you use some freeware tool like blat.exe on the LMS server to try to send an email and see it works fine.
You can either download it from http://sourceforge.net/projects/blat/files/ OR it is usually present in Wind28K server @ C:\Windows\System32.
Check and shae updates.
Joe
