CiscoWorks and HP OpenView
omar.elmohri
Any one can help me do the best integration between LMS and HPOV NNM?
The two tools are installed on separate hardwares.
Joe Clarke
What version of HPOV? What version of CiscoWorks? On what platform is OV installed?
Hello Clarke,
For the platform all is running on Windows 2003 Server.
CiscoWorks is a 2.6 and HP OpenView is 7.51
Use the CiscoWorks CD/DVD on the HPOV-NNM-Server and install only the "Integration Utility". Backup your "trapd.conf" and snmp-configs (or all), because the integration utility abort on errors without informations and your must adjust perhaps the trapd.conf or/and snmp-mib's.
See http://www.cisco.com/en/US/partner/docs/net_mgmt/ciscoworks_common_services_software/3.0/user/nmim/guide/nmim_ug_1.html
