CiscoWorks CM and QOS Policy Manager
mattwilsonuk
Downloaded the Ciscoworks QOS Policy Manager, installed on 2003 SP2
Had an error free installation however everytime I try to run the Qos policy management from the Ciscoworks homepage I get the following error...
"The QPM application is not fully started. Please close the window and try launching after few minutes"
Any ideas... anyone come across this before, I cant find any resources in the troubleshooting section.
Cheers
Matt
There does appear to be a conflict. Try shutting down Daemon Manager. Then, shutdown FrameworkService (I think this is anti-virus related), zabbix, and whatever dbsrv8.exe is associated with. Essentially, try shutting down all third-party services. Then restart Daemon Manager.
13 Replies 13
Joe Clarke
What version of QPM did you install? What version of LMS are you running? Post the output of the pdshow command.
Downloaded the demo packacke form cisco site.
Following these instructions:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_qos_policy_manager/4.1/installation/guide/windows/KIinWIN.html#wp1147270
Have installed Common Services which is all I need as per instructions.
Dont have LMS installed.
Have installed this demo on separate server as per instructions above.
Cheers
Matt
Okay, you said CiscoWorks CM in the subject, so I assumed you had LMS. Post a screenshot of the Common Services > Software Center > Software Update screen from the CiscoWorks homepage. Also, please post the pdshow command output from the server's CLI.
Attached ;-)
Process= Tomcat
State = Program started - No mgt msgs received
Pid = 6016
RC = 0
Signo = 0
Start = 9/10/2009 3:04:40 PM
Stop = Not applicable
Core = Not applicable
Info = Application started by administrator request.
Process= TomcatMonitor
State = Running normally
Pid = 6108
RC = 0
Signo = 0
Start = 9/10/2009 3:04:44 PM
Info = Tomcat Server up
Process= Apache
Pid = 9640
RC = 0
Signo = 0
Start = 9/10/2009 3:05:35 PM
Process= qpmDbEngine
Pid = 8812
RC = 0
Signo = 0
Start = 9/10/2009 3:05:37 PM
Process= qpmDbMonitor
Pid = 8896
RC = 0
Signo = 0
Start = 9/10/2009 3:05:41 PM
Info = DbMonitor Running Normally.
Process= QpmPDP
Pid = 2108
RC = 0
Signo = 0
Start = 9/10/2009 3:05:42 PM
Info = Server started by admin request
Process= QpmAppServer
Pid = 9044
RC = 0
Signo = 0
Start = 9/10/2009 3:05:46 PM
Process= QpmCollector
Pid = 9096
RC = 0
Signo = 0
Start = 9/10/2009 3:05:50 PM
Process= Proxy
Pid = 7272
RC = 0
Signo = 0
Process= NameServer
Pid = 7376
RC = 0
Signo = 0
Process= NameServiceMonitor
Pid = 9380
RC = 0
Signo = 0
Start = 9/10/2009 3:05:54 PM
Info = NameServer is fully up now !
Process= EDS
Pid = 9356
RC = 0
Signo = 0
Start = 9/10/2009 3:05:58 PM
Info = Initialization complete
Process= LicenseServer
Pid = 9024
RC = 0
Signo = 0
Start = 9/10/2009 3:07:16 PM
Process= ESS
Pid = 7212
RC = 0
Signo = 0
Process= EssMonitor
Pid = 7836
RC = 0
Signo = 0
Start = 9/10/2009 3:07:20 PM
Info = ESS is fully up now !
Process= EventFramework
Pid = 6376
RC = 0
Signo = 0
Start = 9/10/2009 3:07:28 PM
Process= emsDbEngine
Pid = 6200
RC = 0
Signo = 0
Start = 9/10/2009 3:07:30 PM
Process= emsDbMonitor
Pid = 8112
RC = 0
Signo = 0
Start = 9/10/2009 3:07:34 PM
Process= diskWatcher
Pid = 8128
RC = 0
Signo = 0
Info = diskWatcher initialized OK.
Process= CSRegistryServer
Pid = 7996
RC = 0
Signo = 0
Info = CSRegistryServer is running in other process
Process= CSDiscovery
State = Never started
Pid = 0
RC = 0
Signo = 0
Start = N/A
Info = Not applicable,
Process= CmfDbEngine
Pid = 1912
RC = 0
Signo = 0
Start = 9/10/2009 3:07:36 PM
Process= CmfDbMonitor
Pid = 7744
RC = 0
Signo = 0
Start = 9/10/2009 3:07:40 PM
Process= DCRServer
Pid = 7612
RC = 0
Signo = 0
Start = 9/10/2009 3:07:41 PM
Info = DCRServer is up and running
Process= CMFOGSServer
Pid = 7748
RC = 0
Signo = 0
Start = 9/10/2009 3:07:52 PM
Process= emsServer
Pid = 8028
RC = 0
Signo = 0
Process= EDS-GCF
Pid = 6804
RC = 0
Signo = 0
Info = GCF Initialization complete at Thu Sep 10 15:09:02 BST 2009
Process= jrm
Pid = 6788
RC = 0
Signo = 0
I don't see any errors here. All processes are up. Post the NMSROOT/MDC/tomcat/logs/stdout.log and stderr.log. What is your current local time?
Files attached... lots and lots of errors here relating to java... not sure how to procede really, updated java client etc...
Local time is correct.
Cheers
Matt
any ideas... only get a 60 day trial ;-(
Sorry, I missed the previous post. There are errors here, but it's not clear what is causing them. This could be a port conflict. on the server. Post the output of netstat -a -n -o -b.
no worries...
ouput attached
Closed zabbix and dbsrv8.exe
working now, thanks so much for you help.
Matt
