CiscoWorks dcrcli - authentication failure
akorsvoll
Community Member
I'm running LMS 2.5 on Solaris 9, and do have a problem running dcrcli:
"<dcrcli> * Warning * DCRCLIFILE Environment variable not set.
Authentication Failed. Verify username and password entered"
I'v tried this with several user-ids, and from root.
Anders
nhabib
Level 11
Level 11
Make sure that you are using a valid CiscoWorks user (such as admin)
akorsvoll
Community Member
I've tried several users which all can login into CW gui
Is your LMS integrated with ACS by any chance?
akorsvoll
Community Member
No, I'm using TACACS+daemon, but have tried to use local authenntication as well.
