Ciscoworks DFM Question
dionjiles
Does Ciscoworks keep a log locally on the server for all the Device alerts?
The reason for this question is I got pinged by an Auditor yesterday seeing if we can obtain this type of information.
Thanks in advance.
maquesad
The log file that has information about the alerts that LMS produces is the
AAD.log. It is located at NMSROOT\log\dfmLogs. The kind of information you
will see in the log file depends on the logging level that you currently
have for it.
Additionally you might want to see the syslog.log which is located at
NMSROOT\log and contains info about the syslogs that LMS receives from your
devices.
Also, LMS has a fault history option in which you should be able to see old
alerts.
Michel Hegeraat
Level 7
Level 7
DFM has fault history, so yes.
But maybe you should be more specific?
What is he trying to find the history of?
Cheers,
Michel
Good morning.
My question was answered via TAC Request
SR 620063009
They are basically trying to see how our monitoring tools keeps a history of all device alerts.
maquesad
have for it.
devices.
alerts.
