CiscoWorks LMS 4.0 Configure
laykomDmitry
Hello.
Could you tell me about the database CiscoWorks LMS.
Can I convert a database CiscoWorks LMS to SQL database.
Thank you.
5 Replies 5
Joe Clarke
LMS uses an embedded Sybase-based database.  It is an SQL database.  Direct access to the full database schema is not available; however, one can access read-only views as documented at
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/database_schema4.0/guide/dbviews.html .
Could you give me an answer the question.
Why I can not add devices to DCR?
I have a problem with the addition of devices to DCR
I add a device to DCR, but the LMS creates a group.
Could You help me.
How do I remove the device from the DCR?
To remove a device from DCR, go to Inventory > Add / Import / Manage Devices, check the device you want to remove, and click Delete.  I'm not sure what you mean by not being able to add devices.  If you're still seeing a problem with this, please start a new thread.
