04-27-2011 11:22 PM
HI,
I have installed CiscoWorks LMS4 on Windows 2003 Server Standard SP 2. Unfortunately, I have only 2 Gb memory and the 2003 server is only allowing 4Gb on Virtual memory.
The installation completed with the warnings:
----- end of Reconfiguring CMF... protocol
INFO: Installation completed at: 22:46:43 ,Wed 04/27/2011 ,Pacific Standard Time
INFO: Installation completed at: 22:46:43 ,Wed 04/27/2011 ,Pacific Standard Time and the user was prompted to reboot
===================- Possible Warnings/Errors Encountered -===================
Warning: Current swap space is less than the minimum requirement of 8192 MB. CiscoWorks processes will not start at the end of installation. Increase the swap space and then start the processes manually.
Warning: System memory is less than required, which may affect performance.
Warning: Current CPU speed is less than the minimum requirement, which may affect performance.
Warning: Current swap space is less than the minimum requirement. This may affect performance.
Warning: Current disk space is less than the recommended disk space (30720 MB), which may affect performance.
WARNING: The memory available 1972 MB is less than the required memory of 4096 MB. User chose to continue the installation.
WARNING: Domain Name is not found from TcpIp parameters,certificate will be generated with the HostName
WARNING: Domain Name is not found from TcpIp parameters, setting PX_FQDN same as PX_HOST
INFO: User Selected to Reboot the Machine
Installation Completed at 22:47:09
The processes does not start so when I start the daemon manager manually, it stalls with the following message:
C:\Documents and Settings\Administrator>C:\PROGRA~1\CSCOpx\bin\dmgtd.exe
REMOVERESOURCE[CCREntry[Core,Custom,Custom,,,CMFPROTOCOL,,,,FALSE]]: CCRRespo
nse[0;The entry is removed. CCREntry[Core,Custom,Custom,,,CMFPROTOCOL,,,,FALSE].
ADDRESOURCE[CCREntry[Core,Custom,Custom,http,,CMFPROTOCOL,,,,FALSE]]: CCRRespo
nse[0;]
Its just for a demo.
Could you please help.
Ashley
04-28-2011 03:41 AM
Ashley,
Unfortunately that server will not be able to start LMS 4.0. The documentation states that the minimum RAM required is 4 GB; and the minimum processor speed must be 2.33 Ghz. Swap space is also importand, but you would be able to get away with 5,1 GB swap space for demo purposes.
Good luck.
P
