04-26-2011 12:17 AM
Hi Netpro Team,
could you please tell if Lms can monitor and get the alert of any Linecards installed in Cisco 6500 series switches ??
If so, how it can be enabled and how to test it using the packet capture with OID to be searched ??
regards
Rajesh
04-26-2011 12:59 AM
Kindly specify what kind of Line cards are they. LMS have DFM which continoulsy monitor the device components periodically by SNMP polling and also able to translate speific trap coming from the devices.
To see what kind of device/ Module supported, here is the device suported list for LMS 3.2
Device Supported list for LMS 4.0
Hope it helps
Gaganjeet
04-26-2011 02:26 AM
04-26-2011 05:15 AM
hi, can anyone check and update my query pls...
04-26-2011 05:46 AM
Yes, the modules you listed are all supported by CiscoWorks LMS. It can actively monitor their fault status (via SNMP query to the switch supervisor) as well as numerous other functions - process traps and syslog events, graphical view, configuration management and change, inventory, upgrade, etc.
Demonstration via SNMP with OID is not very illustrative, but one could perform and snmpwalk on the IP address of the supervisor. (The supervisor performs all the management fucntions of the switch, you would not and generally* cannot query other line cards directly.) The verbose snmpwalk output would have all the information that CiscoWorks parses into more usable form in its various components.
Hope this helps.
* some exceptions with services modules
04-26-2011 05:50 AM
Thanks for the update sir.
Could you please tell me the sysObjID for monitoring any of the module status so that i can do a packet capture of the switch and analyse for the said ID.
~rajesh
04-26-2011 06:10 AM
Attached is a screen shot of what LMS (CiscoView component) would show you of a switch similar to what you describe.
An OID analysis will be much more obtuse, giving you output such as:
iso.3.6.1.2.1.2.2.1.2.1 = STRING: "TenGigabitEthernet1/1"
iso.3.6.1.2.1.2.2.1.2.2 = STRING: "TenGigabitEthernet1/2"
iso.3.6.1.2.1.2.2.1.2.3 = STRING: "TenGigabitEthernet1/3"
iso.3.6.1.2.1.2.2.1.2.4 = STRING: "TenGigabitEthernet1/4"
(this is very partial output of C:\Users\Administrator>C:\"Program Files (x86)"\CSCOpx\objects\jt\bin\snmpwalk -v 1 -c
04-26-2011 06:40 AM
This oid represents the interfaces of each module status... But i would like to know "Does Dfm notifies if any MODULE itself goes down" ?? In this case, how do we do the packetcapture for the module as a whole, in order to confirm that Lms is polling snmp from the switch for Module status rather than the individual port status...?
~Rajesh
04-26-2011 10:51 PM
Hi Netpro Team,
Please revert to this............
04-27-2011 12:08 AM
Dear Clarke, Could you please share your comments on this,,
04-27-2011 02:06 AM
Hi Joseph Clarke ,
Please help me...
problem summary - We are not getting Dfm alerts when any of the module goes down in the cisco 6500 switch.
I got to know about the sysobjid as "1.3.6.1.4.1.9.5.1.3.1.1.10" from the Link " http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.5.1.3.1.1.10#oidContent ". But i am unable to get the said sysobjid from the packet capture taken from the switch with filters as "snmp 161/162/syslog 514" etc.
Can you please help me.
~rajesh
04-27-2011 03:10 AM
Hi Netpro Team,,,,,, Please help !!
04-28-2011 12:18 AM
please reply to this thread.........
04-28-2011 02:36 AM
I myself has searched the solution and it is that the Dfm can poll the module status via the snmp on sysobjectid.
The below link will take you to the sysobjid for the modul status of cisco switches.
The way how you will identify is to do a packet capture option available in Device center with all the ports selected(any) and run it for a cycle of 600 seconds. The OID would be 1.3.6.1.4.1.9.5.1.3.1.1.10.
Object | moduleStatus |
OID | 1.3.6.1.4.1.9.5.1.3.1.1.10 |
Type | INTEGER |
Permission | read-only |
Status | current |
Values | 1 : other 2 : ok 3 : minorFault 4 : majorFault |
MIB | CISCO-STACK-MIB ; - View Supporting Images |
Description | "The operational status of the module. If the status is not ok, the value of moduleTestResult gives more detailed information about the module's failure condition(s)." |
~ PLEASE RATE MY THREAD IF YOU FOUND IT IS HELPFUL...
regards
Rajesh P
04-28-2011 02:42 AM
Hi Rajesh,
This is very Informative....
Best Regards,
Manjesh
