Ciscoworks - RME 4.3.1 Sotfware distribution needs 32MB minimum in Flash
jjiles
I’m having the need to upgrade over one hundred Cat2900 to a newer image. When I run the software distribution application on Ciscoworks (RME 4.3.1) I get the “catastrophic” warning described below. The new image is only 7MB and there are 22MB free in flash. Is there any way to by-pass this requirement checking???
Catastrophic - SWIM1200: Selected Flash partition requires minimum (32 MB) to upgrade selected software/image. Select a different Flash partition for upgrading the image.
test3#show flash:
Directory of flash:/
   2 -rwx         616   Mar 1 1993 00:00:28 +00:00 vlan.dat
   3 -rwx       2861   Mar 1 1993 00:04:24 +00:00 config.text
   4 -rwx           5   Mar 1 1993 00:04:24 +00:00 private-config.text
   5 drwx         512   Mar 1 1993 00:10:44 +00:00  c2960-lanbase-mz.122-35.SE                   5
27998208 bytes total (22688768 bytes free)
-rwx------+ 1 Administrators None 7075041 2011-06-30 13:17 c2960-lanbasek9-mz.12
2-44.SE6.bin
AFROJ AHMAD
Try the below steps and I hope this should work:
1- Go to RME > Software Management > Software Repository 2 - Select the image you are trying to push (Click on the file name) 3- Change the Minimum RAM to a lower value than the RAM you have on the device 4 - Click on Update 5 - Try the SWIM job again
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Afroj
