Ciscoworks with VPN's and PIX's
lfrancisci
I have a customer that has Ciscoworks installed. (Current modules installed are RME, Cisco View, Device Fault Manager, Common Services, Campus Manager)
Can the customer do config pushes to the VPN and PIX devices using what they have installed or do they need something else added to Ciscoworks to do this? Thanks
5 Replies 5
David Stanford
The RME piece of the application should handle this config mgmt.
Have a look at the supported devices list as well for minimum code requirements:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_4_x/4_0_3/sdt/rme403.htm#wp231143
What you need is CiscoWorks VMS (VPN Management Solution) to manage security devices.
I don't think you can do it with CiscoWorks LMS as it is purely for Routers/Switches.
Cheers.
VMS (now CSM) does have additional feature to manage security devices, but RME does have config management capabilities for PIX and VPN devices.
thanks for your highlight. I didn't aware that RME support those devices.
Cheers!
How would I use RME to do this with the PIx's and vpn's? Thanks
