Ciscoworks2000
paltel
Level 5
Level 5
I want to generate daily,weekly, and monthly report for all devices at my network(availability Report using ping). And these reoprts give you in percentage each device success rate. how can i do this in ciscoworks?
Thanks in advance
rmushtaq
Level 11
Level 11
What version of CiscoWorks you have?. In old RME 3.5, there is a function called Availability Monitor, which you can look at
i have Resource Manager Essentials with Update 1 v 3.5. i set a view and changed polling options. i have a question, can i make for example daily, weekly, and monthly reports and these reports sent to my email? i need a percentage for every device (success percentage).
Thank you
3slaverty
Frequent Visitor
Frequent Visitor
did you sort this out ? I have same issue, can only use RME to see raltime availability. Was hoping to produce monthly report on availability without resorting to whatsup gold etc.
