SyslogAnalazer
azinatulin
I install CiscoWorks SNMS 1.5 and all updates - IDUv5 + CiscoWorks Update 1 + IDUv11.
SyslogAnalazer don’t work correctly:
When I try generate “Standard reports“ (Select Essentials > Reports > Syslog Analysis > Standard Reports), appear message:
__________
Invalid Record received from Server, Discarding record.
Recommended Action
Please retry the same operation.
__________
I try re-install CiscoWorks SNMS 1.5 with updates IDUv5 + CiscoWorks Update 1, this message appear again.
In process status (Admin > Server Configuration>
Process Management > Process Status), SyslogAnalazer don't have any errors.
Thanks.
Alexander.
8 Replies 8
k.poplitz
Level 3
Level 3
Please check on the following aspects,
1. What is the Windows 2000 version?
(is it English version?)
2. What is the locale settings? Input locales?
(it should be English)
3. Make sure that all language settings is English.
CiscoWorks SNMS 1.5 does not support any other language besides English and Japanese.
This is documented in the Installation (Prerequisites) Guide.
Check this link,
http://cisco.com/en/US/products/sw/cscowork/ps2408/products_installation_gui
de_chapter09186a00801bc978.html
So please make sure that The Windows 2000 version is English and make sure
that the "locale" settings is also English. I suspect this is the cause of the problem.
I change locale setting.
SyslogAnalyzer work fine.
Thanks.
lauekh
Thanks.
Edward
I changed the locale of my system, but it does not work for me. Whatelse do I need to change?
Thanks.
Edward
nesterove
I have same problem. I installed RME 3.5 with Syslog Analyzer 3.5 IDUv5 + CiscoWorks Update 1 + IDUv10 on W2K Server SP4 (English version). Locale settings - English. All language settings is English.
Then I check syslog.log - it woked correctly - many new messages from routers and switches. For Example:
Jul 28 18:26:11 172.17.6.163 1134: 1w2d: %LINK-3-UPDOWN: Interface FastEthernet0/11, changed state to up
Jul 28 18:26:15 172.17.6.166 2071604: 34w2d: SNMP: Packet received via UDP from 172.17.1.30 on Vlan2
Jul 28 18:26:20 172.17.3.1 98409: 3w4d: %LINK-5-CHANGED: Interface Async44, changed state to reset
But, when I try generate "Standart reports" or any other - a recived same message:
Recommended Action
I not used DNS for this equipment - only IP.
Help me, please!
Thanks.
Evgeny.
Try running Severity Level Summary instead of Standard Reports
Do you get the same error?
Yes. When I running Severity Level Summary, firstly I selecting devices, then dates and finish.
The table is showing. There are many devices in this table with some messages. For example:
Device Name | Emergencies(0) | Alerts (1) | Critical(2) | Errors(3) | Warnings(4) | Notifications (5) | Informational(6) | Total
172.17.6.166| 0 | 0 | 0 | 444 | 0 | 914 | 0 | 1358
When I try click on any of messages groups - I get same messages:
__________
Recommended Action
__________
Evgeny
When I simple changed locale setting - it doesn't work.
Than I reinstalled RME - it does work succesfull !
Evgeny
