Cisoc RV 345
Badegakk
I have Cisco RV345
Router Firmware: 1.0.02.16
I can't find out how to use my 4g usb modem with my router.
Tryed two different 4g usb modems: Huawei E3372 and ZTE MF831
My sim card does not use password
My recognized the Huawei E3372, but wont connect, it says its disconnected.
With ZTE MF831 it wont reconize at all but at least the usb light turns to green, i the controlpanel it says it disconnected.
I very frustraded since i have bought to USB 4G Modem and noen of them work.
Both 4G USB modems works if i directly connect them to my computer, so they do work perfectly.
Please help me with this, also hard to find some kind of support number or e-mail to contact cisco directly. Quess its bery deep some where on the internet.
5 Replies 5
My 4G USB Modem is supported in the US.
I live in Norway, does it mean that this router only works in the US and the UK?
Then i will have to advice my company to look elsewhere for routers.
Best Regards
Michel Le Belu
This list is for the RV324 and not RV345, does they support the same dongels?
Badegakk
My 4G USB Modem is at top of that list Huawei E3372h-153
Badegakk
As you can see it reconizes the modem, but it wont connect.
