12-05-2018 12:20 AM
Hi everyone,
I have a situation like this
The Ethernet Management interface has ip 192.168.5.227/16 but the pc1 connected on the same switch can not establish the connection.
The PC2 connected to another switch, however, can access it without problems.
From PC1 I can access the 2960x switch only if I connect through vlan184.
The Cisco has this configuration on the ports:
Please, can someone explain me why?
Thanks!
12-05-2018 12:32 AM
PC1 is connected to giga 1/0/24. This port is configured in trunk mode.
Is the PC able to handle VLAN?
Can you past the configuration of the switch?
Regards.
12-05-2018 02:34 AM
12-05-2018 05:21 AM - edited 12-05-2018 05:23 AM
Hi, the port giga 1/0/22 is configured in trunk. In this modality, the port handles frame in 802.1q format.
The PC sends the frame in 802.3 format. These frames are not compatible. You can connect a PC to a trunk port if the PC is able to handle VLAN (802.1q frame).
The management IP is configured directly on the F0 port:
interface FastEthernet0
ip address 192.168.224.27 255.255.0.0
This port is not a switch port.
Test this configuration:
1) change the F0 port to switch mode and assign vlan1
description *** MANAGEMENT PORT ***
no ip address 192.168.224.27 255.255.0.0
switchport mode access
switchport access vlan 1
2) assign the management IP to interface vlan 1
interface Vlan1
description *** MANAGEMENT VLAN ***
3) configure the giga 1/0/22 port in access mode and assign vlan 184
interface GigabitEthernet1/0/22
description *** TO PC1 ***
switchport access vlan 184
configure only the IP 10.10.84.250 on PC1
4) enable intervlan routing
ip routing
After this config you should be able to ping the interface vlan 184 and the interface vlan 1.
Let me know the result.
Regards.
12-05-2018 07:06 AM - edited 12-05-2018 07:06 AM
Hi Daniele,
thanks for the replies!
That's what I thought, too, that the absence of the tag on the VLAN 1 prevented me from reaching the FA0 interface of the Cisco switch. But the PC1 can reach any other ip in the subnet 192.168.0.0/16 except 192.168.224.27.
I tried to make the configuration that wrote to me but the FA0 interface does not allow the switchport command (see attachment)
12-05-2018 07:44 AM
Is "ip routing" enable?
Regards.
12-06-2018 11:53 PM
