clogHistTimestamp traps
yjdabear
If I'm getting tons of clogHistTimestamp SNMP traps, does it mean the originating device is configured to send syslogs as SNMP traps, since clogHistTimestamp is defined under CISCO-SYSLOG-MIB? Is there any other way of stopping it than "no snmp-server enable traps syslog"?
m.singer
Level 4
Level 4
you will have to use "no snmp-server enable traps syslog" to disable system logging message SNMP notifications, check out the following link for the "snmp-server enable traps syslog" command reference :
http://www.cisco.com/en/US/products/ps6350/products_command_reference_chapter09186a0080444dd0.html#wp1030781
if you do not need syslog traps(which are sent for every message displayed on the console), disable those traps as follows:
router(config)# snmp-server enable traps
router(config)# no snmp-server enable traps syslog
