CNA 5.8.5.1
GeneralYo
Hi, unable to backup using cna 5.8.5.1. I currently run 5.6.3 and can backup successfully when I upgrade to 5.8.5 I can no longer backup. Have check log which mention firewall and other tftp server, have checked these they are not the problem.
Has anyone experience simpler problems? Or know the cause? Please help!
rajevasu
     I tested the back up in CNA 5.8.5.1(windows 7) and it is working fine.
Not able to reproduce the issue.
Could you please check whether you are able to reproduce the issue, if so tell which device you used to back up, so that I can test the same if I have the device.
Thanks & Regards,
Rajesh Vasudevan
