05-01-2014 07:52 AM
Hi All,
Are there any known issues with CNA 5.8.9.1 compatibility with a C2960X switch running 15.0(2)EX4?
When I attempt to log in to the switch, I am informed the credentials are invalid although the same credentials work when using the CLI.
Best Regards,
-Evan
Solved! Go to Solution.
05-01-2014 09:33 AM
Have you specified the ip http authentication mode on the switches? CNA uses the http server on the target device.
Test your credentials against the device web interface to verify.
05-01-2014 09:33 AM
05-02-2014 08:57 AM
This is what was missing on the switch. Thank you very much Marvin :)
05-02-2014 10:59 AM
You're welcome - glad it helped. Thank for the rating.
