CNA 5.8.9.1 not allowing access to 2960X running 15.0(2)EX4 even though credentials are correct
eharbensc
Hi All,
Are there any known issues with CNA 5.8.9.1 compatibility with a C2960X switch running 15.0(2)EX4?
When I attempt to log in to the switch, I am informed the credentials are invalid although the same credentials work when using the CLI.
Best Regards,
-Evan
Marvin Rhoads
Have you specified the ip http authentication mode on the switches? CNA uses the http server on the target device.
Test your credentials against the device web interface to verify.
Marvin Rhoads
This is what was missing on the switch. Thank you very much Marvin :)
You're welcome - glad it helped. Thank for the rating.
