CNA v5.8.7 and v5.8.8.1 can't add c2960x to community
gti.agetop
In CNA 5.8.7 or 5.8.8.1, I can not add any switch WS-C2960X-48TS-L to the community.
Using Discover like a single device by IP address and device IP, the CNA sends this error:
Error: Create Community
Unsupported Device Type: WS-C2960X-48TS-L
Cannot add device 10.x.y.z to community
How to proceed?
2 Accepted Solutions
Marvin Rhoads
You'll need to watch for a new release of CNA that adds 2960X support. Until then, you cannot manage it with CNA.
CNA tends to be updated 2-3 times a year adding new device support. Right now the release notes show it indeed does not manage the 2960X.
sriachan
    I am Srikanth from CNA dev engineer team. C2960X and C2960XR devices will be supported in CNA feature release(i.e CNA589). CNA589 is going to release by end of November.
Thank you
Srikanth Achanta
5 Replies 5
Marvin Rhoads
sriachan
Thank you
Srikanth Achanta
I will wait the new release with very big expectations.
ru-user-ciko
Hi  from University of Ruse, Bulgaria. I installed the new version of Cisco  Assistant and noticed a problem. We have new switches WS-C2960X-24TS-L.  CNA view this devices in Front Panel like Catalyst 2960-S. Screen of  the problem -
http://www.uni-ruse.bg/.ntk/cisco_CNA_5_8_9-University_of_Ruse.PNG
Hi Nikolay ,
It seems this is an issue , we have filed an defect for the same ,
CSCum09576  , We will fix this and let you know the updates
