[CNR 7.2] Installation
Carlos A. Silva
Level 3
Level 3
Hi, All:
I'm reviewing the process of upgrading a CNR6.2 to CNR7.2. It reads simple enough, but I have the following question: customer does not require to keep current database, so: instead of treating the the upgrade process as an upgrade, is it ok to run the clean installation process on the server? Is there anything I should keep in mind when doing this?
Thanks in advance!
c.
Nael Mohammad
Level 5
Level 5
To upgrade to CNR 7.2, you must first migrate to CNR 6.3.x or higher. Since you mentioned the customer does not care about the previous configuration, then uninstall the previous version of CNR using the uninstall script that's included with the software.  Once the removal is completed, install the new version.
Ensure that your system meets the prerequisites before starting CNR 7.2 installation. Here is the release notes:
http://www.cisco.com/en/US/docs/net_mgmt/network_registrar/7.2/release/notes/CNR72ReleaseNotes.html#wp89948
