03-27-2012 07:03 AM
nrcmd> server dhcp start
320 TRE_NOTLOADED - Bad id or server not loaded.
any help please?
Solved! Go to Solution.
03-27-2012 11:01 AM
Which version of CNR and any OS changes recently?
If this is Linux run the following commands:
bash export LD_LIBRARY_PATH=/opt/nwreg2/local/lib /opt/nwreg2/local/bin/dhcp -v (Change the path based on the installation if needed)The dhcp -v will either work and display a bunch of version information OR it will indicate that libraries are missing and which ones.
03-27-2012 11:01 AM
03-27-2012 10:33 PM
CNR version is 8.0
OS - rhel 6.2 (clean install)
03-27-2012 11:27 PM
many thanks.
your answer helped isolate the problem.
CNR needed openldap version 2.3, installed on the server version 2.4
downgrade these packages is not possible.
symlinks resolve the issue.
