command history for all telnet sessions
heshengchun
Is there way to get all command session history instead of current session history without using syslog/snmp server?
nhabib
Level 9
Level 9
No, you would require the Accounting portion of AAA
Do you know the answer for my previous question?
we have problem for one 3750, it's not pingable/telnet from outside ( neither interfaces or any VLAN ), the only way to get in is from console, I can not ping out once I console in and it seems functional normally, all interfaces still take traffic ( this is core switch, we have a lot of voip traffic on it ), the configuration has not been changed since it was turned up, there seems no error in log.
What could be the problem? Is it ARP related?
Thank you so much!
sorry, I am not sure what could cause this
Could you please help me to set up syslog config in order to get all telnet session command history?
from my syslog server 10.1.1.2, I can only get brief info using the following config,
logging buffer
logging 10.1.1.2
