Config archive failure for al the devices
vaibhav-g
Schedule backup of LMS server is not happening and apart from this config achieve of all device in RME showing failed.
Please find the attached screenshot of problem.
Vaibhav
5 Replies 5
Joe Clarke
Post the dcmaservice.log. What version of RME is this?
Hi Clark
Rme version is 4.0.6
LMS 2.6
plse find the dcmaservice.log
Vaibhav
There is a problem with the archive on disk. Assuming that you have properly configured the archive under RME > Admin > Config Mgmt > Archive Settings, then try removing one of the problem devices from RME, then re-add it. See if the config can be successfully archived then.
Hi Clark
I have done the same,it is working i have deleted one of the device and afer adding Archive is happening but i have so many devices.how we can solve this issue manually doing will take so much time.Kindly suggest
Vaibhav
You will need to do it for all of the failing devices, or you will need to reinitialize the RME database:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=rmeng dmprefix=RME
