Configuration of a cisco c921-4P Dual Wan Port
scsawyer
Hello
I need help on setting up the two wan ports on the router for load balancing, they need to be DHCP on the port 4 and 5. I can make it work with one wan port just having figured out how to add the second wan port. any help would be great.
5 Replies 5
ashish.kushwaha
you can add second wan link in router and use IP SLA feature or PBR to perform load balancing.
Ashish K
***Please Rate Helpful Responses***
post the running configuration of your 921 router. The easiest way to achieve load balancing/load sharing is to just configure two static default routes:
ip route 0.0.0.0 0.0.0.0 WAN_PORT_1
ip route 0.0.0.0 0.0.0.0 WAN_PORT_2
Really, i would have figured it would have to more in the Configuration then just that. guess i am over thinking it.
two static routes is probably not really enough. You need to configure th NAT as well, so both interfaces are being used. This would look something like below:
ip nat inside source route-map ISP_1_RM interface WAN_INTERFACE_1 overload
ip nat inside source route-map ISP_2_RM interface WAN_INTERFACE_2 overload
access-list 101 permit ip LAN_SUBNET MASK any
route-map ISP_1_RM permit 10
match ip address 101
match interface WAN_INTERFACE_1
route-map ISP_2_RM permit 10
match interface WAN_INTERFACE_2
Run
Per-packet load shearing
And config two default route one for each wan port
