configure a cisco router or a switch through snmp
achikhdaho
I want to know if it possible to configure a cisco router or a switch through the snmp and not through the CLI. Example set or change the ip address of an interface, set the vlan of a switch port, etc
Best regards,
Abdelkader
Leo Laohoo
Yes.  It's possible.  CiscoWorks and SolarWinds Engineers Toolset are two applications I know that can do this.
Thank you very much for your prompt reply.
In  my case I am trying to write some scripts that will automate the provision of ports, vlans and interface vlan, trunks, etc. Do you know where I can find some documentation about which OIDs I should use?
Best regards,
Abdelkader
Hi.
Have a look to this site: http://www.oidview.com/mibs/9/md-9-1.html
This site is used by myself for the most informations about OID's I need.
One note to the comment above: CiscoWorks Config Management uses telnet to configure the switch or router ...
If you want to use snmp only, use Solarwinds (like described) or http://www.softpedia.com/get/Network-Tools/Network-Information/SNMPGetSet.shtml
have also a look to http://sourceforge.net/search/?q=snmp+set      (net-snmp or tcl snmp tools)
Markus
