Configuring EEM on n5k and n7k
Nell_Ko
Gretings community!
My client has two different nexus
  Nexus 5548 / 7.0(8)N1(1)
  Nexus 7710 / 6.2(16)
I was configuring EEM and faced a problem.
Before I open a case, I would like to make sure
there is a solution to it.
configurations were
  event manager applet Link_Down_01
  event syslog pattern Interface Ethernet1/2 down
  action 1 syslog msg LINK_DOWN
it was working fine until I faced the following msg.
It says "Max Limit for syslog EEM events reached !!"
Does it mean that I can configure only few EEMs?
As for n5k, I was able to configure 10 EEM patterns
and as for n7k, I was able to configure 30 EEM patterns
I remember that I read a refrence which stated that nexus supports 500 EEM, but it seems that I can't.
Does that mean I can create 500 EEM but only few patterns?
Another problem is that EEM isn't working properly.
I'm not sure whether I missed something.
configurations were
According to the configuration above,
when the Eth1/2 is down,
I'm suposed to receive a syslog "LINK_DOWN"
but I was only getting "Configured from vty by admin on vsh.#####"
If I change "action 1 syslog msg LINK_DOWN" to "action 1 syslog priority informational msg LINK_DOWN"
and when Eth1/2 is down,
I do get receive "LINK_DOWN" but also the "Configured from vty by admin on vsh.####"
Is this normal or an OS bug?
Mark Malone
EEM syslog is limited to 10 in nx-os from memory
This action 1 syslog msg LINK_DOWN should be action 1 syslog msg "LINK_DOWN" if thats what your capturing in logs
Yes it could be a bug , this is from a 6k nx-os but same bugs can generally appear in each model as its can be unified software same style , you could confirm with TAC or check the release notes for that version see of the caveat is listed
Bug Search
CSCux34522
Help | Feedback Feedback
%VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin on vsh.
CSCux34522
Mark Malone
Bug Search
CSCux34522
CSCux34522
Thanks!
It was an OS bug. I was had bit more of research just to make sure
and it is was a bug.
n5k and n7k has EEM limitation of 20~30.
I am not sure about the exact number but it was around 20~30.
