06-08-2021 11:57 AM
Hello-
Is NetFlow supported on C7200 (C7200-JS-M) router - IOS 12.2(15) T7 & ROM: 12.2(4r) B? I can't find any documentation saying no or yes? This router has live traffic, which is why I didn't add the NetFlow configs to see if it will work. NetFlow can use memory and CPU processes, so I don't want to add this function unless I know fore sure there won't be any issues.
Platform: Cisco 7206VXR (NPE400)
Thanks in advance.
Tony
Solved! Go to Solution.
06-08-2021 12:14 PM
12.X onwards it has support ( 7200 been Long cant remember any more now)
Netflow does not cause any issue with Live traffic, so you can configure offline, only take effect when you apply the flow on the interface., so that time keep monitor device CPU or process.
06-08-2021 12:14 PM
06-08-2021 12:26 PM
