Console LED is ON
Vivek_Mani
In our switch the Console LED is on, there is no active connections in the console port, but still LED is on.
Can someone help me out here ?
here is the document for the 2690-X
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/hardware/installation/guide/b_c2960x_hig/b_c2960x_hig_chapter_01.html#ID526
Console LEDs
The console LEDs show which console port is in use. If you connect a cable to a console port, the switch automatically uses that port for console communication. If you connect two console cables, the USB console port has priority.
Table 9 RJ-45 and USB Console LEDs
LED
Color
Description
RJ-45 console port
Green
RJ-45 console port is active.
When this LED is on, the USB console port LED is off.
Off
The port is not active, and the USB console port is active.
USB console port
Green
When this LED is on, the RJ-45 console port LED is off.
Off
The port is not active, and the RJ-45 console port is active.
Ethernet Management Port LED
Table 10 Ethernet Management Port LED
Color
Description
Green
Active link to PC.
Off
Inactive link.
Amber
POST failure.
BB
balaji.bandi
What is the Model of the Device ? check any one pressed Mode button  ?
BB
Balaji, the model is 2960-X Series. Not aware if anyone has pressed the mode button, as it is in central server room.
Console LEDs
LED
Color
Description
RJ-45 console port
Green
Off
USB console port
Green
Off
Color
Description
Green
Active link to PC.
Off
Inactive link.
Amber
POST failure.
BB
