02-25-2012 06:44 AM
I am trying to copy my IOS to my pc using Solarwinds.
Solarwinds is Started.
I am able to ping from my pc to the fa0/1 port on my switch.
These are in the same subnet.
Pinging 192.168.1.100 with 32 bytes of data:
Reply from 192.168.1.100: bytes=32 time<1ms TTL=255
Reply from 192.168.1.100: bytes=32 time=2ms TTL=255
Ping statistics for 192.168.1.100:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 2ms, Average = 0ms
Switch(config-if)#do ping 192.168.1.50
Sending 5, 100-byte ICMP Echos to 192.168.1.50, timeout is 2 seconds:
Here is the error...
Switch#copy flash tftp
Source filename []? c3550-ipbasek9-mz.122-25.SEB4.bin
Address or name of remote host []? 192.168.1.50
Destination filename [c3550-ipbasek9-mz.122-25.SEB4.bin]?
%Error opening tftp://192.168.1.50/c3550-ipbasek9-mz.122-25.SEB4.bin (Timed out)
appreciate any help.
02-25-2012 07:34 AM
Normal TFTP behavious demands the target file exists on the server and is writable.
Can you confirm the file exists?
Cheers,
Michel
02-25-2012 02:26 PM
Duplicate post.
