Copy running config to startup - Ciscoworks LMS 4
paulnuffer
We were having a discussion in my group about startup vs running configs, and how often some network managers forget to "click save" when they configure a switch.  Is there a way to configure Ciscoworks to copy the running config to the startup?  I thought I saw one in the config archive jobs, but I can't find it now.
Paul
AJ Cruz
Level 3
Level 3
You can definitely create a CiscoWorks job that issues the "copy run start" command, but I assume you're wanting it to be a recurring job. I can't remember if CiscoWorks can do recurring jobs...
Or you could just do it from the router itself with an EEM script. Something like:
event manager applet WRITE_MEM
event syslog pattern "%SYS-5-CONFIG_I: Configured"
action 1.0 cli command "wr"
action 2.0 syslog msg "Change detected, saving config..."
LMS also has the out of sync report that you can use as a basis for the sync
Not sure if this can be scheduled though
Cheers,
Michel
