copy tftp: to bootdisk:
dmcleish
Can anyone share a python netmiko  3.9 script to copy a file from a tftp server to the bootdisk: of a 6800 series switch.
I am using python netmiko on a windows 10 computer.
Would like to put all the switch names  in a file.
balaji.bandi
check below thread example:  copy the config to TFTP - you can do another way around.
https://community.cisco.com/t5/network-management/script-to-copy-running-config-to-tftp-server/td-p/4092699
https://github.com/ktbyers/netmiko/issues/528
BB
dmcleish
Hi All,
I have looked at all these sites and they do not work.
Can someone just post a working solution in this thread.
Joseph W. Doherty
I'm several years out of date, but Python and net library support (then) had been lacking for Windows hosts.  Linux, though, was a different story.  If you can use a Linux hosts, it's possible, your prospects might be better.
