DHCP Problem when NAT is Enable
AlexBar76
I've a trouble on a simple configuration.
I need to connect a cisco c1111 router with a modem tooway,
the cisco have the gigabiteth under dhcp and need to acquire the address from the tooway
from the other side I have some clients that need to access to internet and also the cisco c1111 made a tunnel gre on another site for a private connection
no problem even i insert the nat rule on cisco so this stop to acquire the address from DHCP
if i remove the nat rule this start to work again and take the ip from tooway dhcp
but i need the nat for the internet connetcion for the clients
Any solution ??
Thanks a lot
Alessandro
the problem is most likely that the access list (197) used for NAT has 'permit ip any any' configured, which does not work for NAT.
Change the access list to:
ip access-list extended 197
10 permit ip 10.0.0.0 0.0.255.255 any
20 permit udp any any eq bootpc
5 Replies 5
balaji.bandi
I believe you need to exempt the IP range from NAT exemption.Can you post the configuration show run from the device . and explain where is the DHCP Server and remote VPN address?
BB
AlexBar76
Thanks, this is the configuration, i've put a note on the ip nat
do not see the tunnel because i'm not already made firs i need to solve the DHCP problem
many thanks for you help
A
Many thanks
Yes now the DHCP aquire without problems
I Have also modify the defaul route in this way
ip route 0.0.0.0 0.0.0.0 gigabitethernet0/0/1 dhcp
Many thanks for you support
regards
Alessandro
i may be late here, glad to know all working by removing that ACL, thank you.
BB
