ANI database and dbReader
GeorgeLarson
LMS 2.2
When I use dbreader to show tables for ANI database, I get no tables. I do not get an error message, just the header but no tables. What should I be seeing?
Also, where does it store the Campus Manager data, is it in the ANI database?
5 Replies 5
yjdabear
username: dba/cmfDBA/cwsiSA (ANI)
db name: rme/cmf/ani
The last pair returns this:
Table Information for database: ani
Name Owner Type
EmbuPhoneTracking cwsiSA TABLE
EmbuTrafficParamTmpl cwsiSA TABLE
EmbuUserTracking cwsiSA TABLE
OK, but how about my second question. What I am trying to do is run validation between what is in RME to what is in Campus Manager(Topology Groups).
Which database holds the Campus Manager (Topology Group Data)?
In the same ani db, there're a lot Wbu* groups, including a couple of WbuTopo* groups, but I can't make sense of the data with what I see in the Topology Groups in Campus Manager GUI.
Don't know what kind of validation you're looking to do. As you may be aware, there're a couple of tabs in Server Config -> Setup -> ANI Server Admin, to enable "device synchronization" between RME to Campus Manager.
Topology Groups are in the cmf database.
Yes, we do the sync every night, but we want to be able to run a manual (via excel/access) validation between the hosts in the RME and the host that show up in the ANI/Campus Manager.
