Correct swap memory allocation in LMS 3.2
lauraherr
We have installed the LMS 3.2 in a virtual machine and we wonder if the swap memory configuration is correct. The requirements indicate that the machine needs 8GB of swap space, and, although we have assigned it to the application, we are not sure if we have done in right way. Should be all the 8GB allocated in the drive S: [Swap]?
Thanks in advanced!!
Best regards,
Laura Herrero
Michel Hegeraat
Level 7
Level 7
Looks OK
Assuming both swapfiles are on  local drive partitions
Also turn off Data Execution Prevention except for windows programs
Cheers,
Michel
In my server is checked the "Turn on DEP for essential Windows programs and services only" option, what does DEP mean for CiscoWorks? In windows services there are CiscoWorks services as well, they should be on or off?
Thanks!!
Cheers,
Laura
It should be off IMHO
Cheers,
Michel
