01-24-2017 10:20 AM
Hi all,
i've CPI 3.1.4 DP7 installed and when discovering N9K-C9372TX-E the CPI recognize them as unsupported cisco device.
after reading in the device supported i found out the N9K is suppose to be suppurated from any NX-OS version.
does anyone have answer,
thanks in advance
01-24-2017 11:12 AM
Same problem here but with N9K-93180YC-EX. I opened a TAC-case and got this link in response:
https://app.smartsheet.com/b/form?EQBCT=ad5db7886b774d9abb8ff61a6051cb95
J
01-31-2017 01:28 PM
i opened a TAC.
here is the answer:
i use this url on the CPI to run SNMP WALK to device,
TAC - email
" Navigate your browser to the following location
and then we found out that the supported device has a different OID from the one we manged in the CPI:
N9K-C9372TX-E OID 1.3.6.1.4.1.9.12.3.1.3.1713
the supported device is:
Cisco Nexus 9372TX Switch OID:1.3.6.1.4.1.9.12.3.1.3.1627
be noted that the E is missing, i dont know why Cisco is taking time to add a device when the family are already supported??
hope that helped
