CPU utilization using snmp
sheldonscott
Hey guys,
Need help with snmp configurations on the router or pix which will send cpu utilization messages to syslog server.
5 Replies 5
nhabib
Level 11
Level 11
SNMP and Syslog are independent protocols. Not sure which one you are looking for. These two links regarding monitor CPU and PIX via SNMP may be helpful to you:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094a94.shtml
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094a13.shtml
Yes, I want to get messages sent to the syslog server when the pix or router CPU reaches a threshold. This way I am alerted of heavy usage on the pix or router. thanks again for you help
ericchan2004
Community Member
You may want to take a look at this link which is more relevant to your question- CPU Thresholding Notification.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_white_paper09186a00801cd87d.shtml
Cheers,
Eric
Thanks a lot ericchan. This is exactly what I was looking for.
Scott
Hi Eric ,
I was checking your update i also have same requirement of CPU Thresholding Notification of my PIX Firewall 535 VER 6.3 but currently the document is not available on the given URL BY YOU ...Will you please provide me the correct one .
My mail is is [email protected]
Thanks in Advance
regards
Shariq
