ā06-07-2024 03:24 PM
I am trying to create a test between 2 internal servers at different sites across our IPSec tunnels (WAN). I am not seeing an option to do this, the drop down for agent wants me to to pick something external but I want to create end to end tests between internal devices/systems. Unless I am in the wrong place to create this.
Thank you.
ā06-07-2024 07:22 PM
If you looking to test over IPSEC tunnel then they should be allowed list and accept the traffic, are they mesh tunnels ?
if you looking to test end to end - then if the traffic need to go via tunnel only.
ā06-10-2024 07:47 AM
Hi Balaji,
I have 4 IPsec tunnels for redundancy across different ISP's. I was looking to create end-to-end checks.
ā06-10-2024 10:46 PM
again this insufficient to work ?
end to end test :
1. you looking reachability ?
2. bandwidth ?
3. performance ?
you can do various methods.
ā06-09-2024 02:58 AM
Ping will do job
But you need to select source it must be same as IPsec ACL
MHM
ā06-10-2024 06:26 AM
The OP does not provide much information about the environment and that makes it difficult to give good advice. As a starting point can you tell us what platform this is on? And providing the current configuration (with sensitive information masked) might help us understand better.
ā06-10-2024 07:50 AM
Hi MHM,
I see that I can select ICMP under Network in the create new test. Do I set it up so the agent on one side of the tunnel pings the other side of the tunnel or is there a way to have it ping just end to end from the tunnel itself?
