credential set policy is not working in LMS4.0
ROMAN TOMASEK
I have a problem with credential set policy. I created five credentials sets and I configured policy based on IP Range for these credential sets (see the attachment). When I created a report for credentials verification, the following message appeared: "None of the devices have credential verification data."
I tried to run discovery again, but the result is same:-(. Only when I configured credentials for all devices manually, the verification report is success. Is this a known behaviour or is it a bug?
Thank you.
Roman
Thomas Masters
It is my understanding that this only is applied to newly discovered devices as they are added to DCR.
I recommend you remove a device from DCR and then run discovery to see if it updates accordingly.
Hello Thomas,
thank you for your replay. Are you sure about it? It means that I can't use new credentials policy for the current devices. So when I will change credentials on the devices, I will have to remove and rediscover again these devices???? It is horrible:-( Thanks Roman
I am having a similiar problem. i unmanaged the devices then deleted them. i then ran another discovery but the same old values are used for the devices discovered even though i updates the credential sets.
