CS 3.0.4 - Device Summary Window is Blank
patrick.roche
I recently upgraded to Common Services V.3.0.4. When I bring up the Summary Window via Device Centre - Select Device it is blank. Function buttons are still available.
LMS is 2.5. Platform is Solaris 5.8.
Anyone got any ideas why this might be happening?
Pat
Joe Clarke
This is typically a problem with Tomcat. This used to be an issue when a proxy server was set, but that is fixed in CS 3.0.4. Therefore, the problem should generate an error in /opt/CSCOpx/MDC/tomcat/logs/stdout.log. If you tail -f this file then reproduce the problem in Device Center, you should see a Java stack trace or some other kind of error.
Here's some of the error log that was generated when trying to bring up the device summary.
What do you advise?
:::[Mon Jun 26 10:24:33 BST 2006] Context:/cwhp SessionID:69C50DF0EE967096A3F20DC4AB0D621C CoreID:094E567EC2AD479176BA74805C00C1E1
[Mon Jun 26 10:24:33 BST 2006] CoreContextNexus ValidateConnection:true
[Mon Jun 26 10:24:33 BST 2006] Invoke doLicenseCheck!
[Mon Jun 26 10:24:33 BST 2006] DoLicenseCheck Returned:true
[Mon Jun 26 10:24:33 BST 2006] UII Tasks found! Lookup for CAM Tasks and then call CAM APIS!
[Mon Jun 26 10:24:33 BST 2006] Task name cmf_dc found in the UII Tasks XML file. Fetching the privileges!
DEBUG:appID for context:/cwhp from CCR:cwhp
[ Mon Jun 26 10:24:33 BST 2006 ] INFO [DeviceCenterAction : perform] : Inside Device Center Action class
[ Mon Jun 26 10:24:33 BST 2006 ] INFO [DeviceCenterAction : perform] : Starting Threads
[ Mon Jun 26 10:24:33 BST 2006 ] INFO [DeviceCenterAction : perform] : End of starting Threads
[ Mon Jun 26 10:24:33 BST 2006 ] INFO [DeviceCenterAction : perform] : Start of OGS Processing
[ Mon Jun 26 10:24:33 BST 2006 ] INFO [DeviceCenterAction : perform] : End of OGS Processing
[ Mon Jun 26 10:24:33 BST 2006 ] INFO [DeviceCenterAction : run] : Inside Run method
[ Mon Jun 26 10:24:33 BST 2006 ] INFO [DeviceCenterAction : run] : Getting Cache instance
[ Mon Jun 26 10:24:33 BST 2006 ] INFO [DeviceCenterAction : run] : Creating CMIC Interactor instance
[ Mon Jun 26 10:24:33 BST 2006 ] INFO [DeviceCenterAction : run] : Getting DCR Instance
[ Mon Jun 26 10:24:33 BST 2006 ] INFO [DeviceCenterAction : run] : Obtained DCR Instance
[ Mon Jun 26 10:24:33 BST 2006 ] INFO [DeviceCenterDeviceFilter : createGroups] : Inside Creategroups function
[ Mon Jun 26 10:24:33 BST 2006 ] INFO [DCRInteractor : getPIDMData] : Inside the function getGroupsAndObjects
[ Mon Jun 26 10:24:33 BST 2006 ] INFO [CMICInteractor : GetApplications] : Inside function GetApplications
[Mon Jun 26 10:24:34 BST 2006] INFO [CMICLogger : info] : com.cisco.nm.cmf.cmic.registry.SearchRecords Total number of records to search :128
[Mon Jun 26 10:24:34 BST 2006] INFO [CMICLogger : info] : com.cisco.nm.cmf.cmic.registry.SearchRecords Matched records number :38
[ Mon Jun 26 10:24:34 BST 2006 ] INFO [CMICInteractor : GetApplications] : CMIC return hash size is = 6
[ Mon Jun 26 10:24:34 BST 2006 ] INFO [DCRInteractor : getPIDMData] : PIDM return hash size is = 1061
[ Mon Jun 26 10:24:34 BST 2006 ] INFO [DeviceCenterDeviceFilter : createGroups] : returning from Creategroups function
[ Mon Jun 26 10:24:34 BST 2006 ] INFO [DeviceCenterAction : perform] : obtained parameters are :[ DeviceID = null ] and [ device = null ]
[ Mon Jun 26 10:24:34 BST 2006 ] INFO [DeviceCenterAction : perform] : obtained ipAddress =null
[ Mon Jun 26 10:24:34 BST 2006 ] INFO [DeviceCenterAction : perform] : obtained objectId =null
[ Mon Jun 26 10:24:34 BST 2006 ] INFO [DeviceCenterAction : perform] : obtained displayName =null
What do you advise?
Problem sorted.
I was using Java 1.4.2_04, now upgraded to 1.4.2_10 which works fine.
