CSPC Tool help
smartboy2255
Level 3
Level 3
Dear all,
   Can you please help , how to run CSPC tool.if you have good documents pls share me.
1.Whether server is mandatory to run CSPC tool?
2.If yes can I run Server in Windows system?
Ajith
Marvin Rhoads
The abbreviation CPSC makes no sense to me. What product are you asking about?
abolsaoud
Community Member
There are two ways to install CSPC,
1- using ISO image to be installed on PC (fresh installation): this doesn't reqiure any OS to be installed on your PC, all what you need is just boot from the DVD and install it
2- install it on using a VM softwares, you can use VMware player 4.0 or ESXi 4.x &5.0
download link:
http://www.cisco.com/cisco/software/release.html?mdfid=283114009&reltype=null&relind=null&softwareid=283308676&os=null&rellifecycle=null&release=SNTC%201.6&flowid=
Installation Guide:
http://www.cisco.com/en/US/docs/net_mgmt/smart_portal/Common_Services_Platform_Collector_Quick_Start_Guide.pdf
