CUOM 2.2: PIFServer process doesn't start.
leorob123
Level 3
Level 3
Dear Folks,
CUOM 2.2 doesn't able to start the PIFServer process
c:\>
pdshow PIFServer
Process= PIFServer
State = Failed to run
Pid = 0
RC = -2
Signo = 1073741822
Start = N/A
Stop = 11/20/2009 2:24:31 PM
Core = Not applicable
Info = Application failed or was registered incorrectly.
From PIFServer.log file
Informational:  ANIServer starting Cisco Process Manager communication thread
The connection with the server has been established
java.lang.NullPointerException
at com.cisco.nm.ani.server.framework.POStore.setNextDbId(POStore.java:883)
at com.cisco.nm.ani.server.framework.POStore.computeNextDbIds(POStore.java:918)
at com.cisco.nm.ani.server.framework.POStore.internalPopulateDataModel(POStore.java:1413)
at com.cisco.nm.ani.server.framework.POStore.populateDataModel(POStore.java:1491)
at com.cisco.nm.ani.server.frontend.AniMain.loadFromDatabase(AniMain.java:355)
at com.cisco.nm.ani.server.frontend.AniMain.dynamicInitialize(AniMain.java:441)
at com.cisco.nm.ani.server.frontend.AniMain.main(AniMain.java:554)
ANI Server failed to load from the database.
Please stop and restart the system. You may need to re-initialize the database.
If this does not work, please contact technical support.
I re-initialized the DB but no changes affect the PIFServer process...
Anyone knows what I'm hitting?
Ciao
Leonardo
Nael Mohammad
Level 11
Level 11
Post the pdshow output from the dos prompt:
"pdshow > pdshow.txt"  and check you event viewer for any errors as well with a screenshot.
-nael
