403 Forbidden error
jackymasibo
Hi People,
I seem to have another problem,when I try to access the Ciscoworks LMS server from the web browser after  logging in it displays the 403 forbidden error message as attached below.Please anyone with an idea on what could be possibly wrong should help me.
Thanks.
5 Replies 5
Joe Clarke
Post the output of the pdshow command from the server as well as the NMSROOT/lib/classpath/md.properties and NMSROOT/MDC/etc/regdaemon.xml files.
Hi Jclarke,
Please find the attached for your further assistance.
As I suspected, your service startup parameters have been modified which breaks LMS.  Post screenshots of your Services control panel showing all of the CiscoWorks services.  At the very least, it looks like the CiscoWorks Web Server service was set to Automatic when it must be Manual.
Hi Jclarke,
I have attached the Screenshots for your further assistance.
Like Joe stated, you need to revert the process back to their original settings .
CiscoWorks AniDatabase = Manual
CiscoWorks DaemonManager = Automatic
CiscoWorks RME NG Database = Manual
CiscoWorks Tomcat Server = Manual
CiscoWorks Web Server = Manual
CWAFEngine Database = Manual
CWCS CMF Database = Manual
CWCS rsh/rcp = Automatic
CWCS syslog = Automatic
CWCS tftp = Automatic
DFM dfmEpm Database = Manual
DFM dfmFh Database = Manual
DFM dfmInv Database = Manual
All the services need to be in the correct state for CiscoWorks LMS start up correctly. The daemonManager calls for all the services to start in a specific order otherwise you will get error encountered. After you make the changes, reboot your server so the process can startup correctly.
-nael
