11-08-2012 03:33 AM
I have installed Cisco Works LMS 3.2.If I go to Campus Manage - Visualization - Topology service, I couldnt see the topolgy.First time it was asking install java. After install Java it is not work. Again and again it is asking install java and the system asking 'you want overwrite' but the topology view is not open.
You should use the supported Java Plug-in version 1.6.0_11 for accessing CiscoWorks Applications. We recommend that you uninstall other Java Plug-in versions from the client machine.
Note You will be asked to install Java Plug-in 1.6.0_11, when you invoke applications that use plug-in. For example, Campus Manager.
Please advise how can rectify this issue and see teh topology ?
Thanks and Regards,
Shahul hameed.
11-08-2012 07:10 AM
You can check if it is properly installed. go to control panel > Java and see Java > View and see what version is there. if other version is there too, try to uncheck it and keep the supported (1.6.0_11) box checked.
I would recommend to try with different browsers a couple of time, like supported FF or IE.
-Thanks
11-08-2012 07:13 AM
Before trying it in browser, please remove the temp files for java as well. From Java > General > Temp Internet Files > view > delete all there.
11-11-2012 04:35 AM
Hi Vinod Arya
I tried as you said but it is not working. After I installed Java restart the PC but no work. It is asking again java installation page. After some times there was update for java 1.6.0_37 I installed that also but no result.Please advise is there any other way to trouble shoot ?
Thanks and Regards,
Shahul Hameed
11-11-2012 04:51 AM
Did you also tried with diff. browsers like FF or IE??
Please enable Java console and share the output after trying to launch the Topology.
You can enable Java console from Control Panel > Java > Advanced > Java console > show console.
This should be enabled on yout client machine, or wherever you are trying to run the toplogy service. Please also confirm, if you server is DNS resolvable from the PC you are trying? If not try to add the service details on /etc/hosts file.
-Thanks
11-11-2012 10:47 PM
Dear Vidon Arya
Please see the console output.
I tried with other browsers also, same issue.
My CW LMS is not in the domain.I installed 2 years back and it was working upto last month.
Java Plug-in 10.9.2.05
Using JRE version 1.6.0_11-b03 Java HotSpot(TM) Client VM
User home directory = C:\Users\Hameed
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to
Match: beginTraversal
Match: digest selected JREDesc: JREDesc[version 1.6+, heap=-1-536870912, args=null, href=null, sel=false, null, null], JREInfo: JREInfo for index 2:
platform is: 1.6
product is: 1.6.0_11
location is: http://java.sun.com/products/autodl/j2se
path is: C:\Program Files (x86)\Java\jre1.6.0_11\bin\javaw.exe
args is: null
native platform is: Windows, x86 [ x86, 32bit ]
JavaFX runtime is: null
enabled is: true
registered is: true
system is: true
Match: selecting maxHeap: 536870912
Match: ignoring InitHeap: -1
Match: digesting vmargs: null
Match: digested vmargs: [JVMParameters: isSecure: true, args: ]
Match: JVM args after accumulation: [JVMParameters: isSecure: true, args: ]
Match: digest LaunchDesc: null
Match: digest properties: []
Match: JVM args: [JVMParameters: isSecure: true, args: ]
Match: endTraversal ..
Match: JVM args final: -Xmx512m
Match: Running JREInfo Version match: 1.6.0.11 == 1.6.0.11
Match: Running JVM args mismatch: have:<> !satisfy want:<-Xmx512m>
Exception in thread "thread applet-com.cisco.nm.ani.clients.campus.main.CampusMain-1" java.lang.NullPointerException
at com.sun.deploy.cache.Cache.getCacheEntry(Unknown Source)
at sun.plugin2.applet.viewer.JNLP2Viewer$1$3.appletJRERelaunch(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.fireAppletJRERelaunch(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Thanks and Regards,
Shahul Hameed
11-11-2012 11:14 PM
Is your server is a Windows server? if so, please check if you can lauch and run toplogy on the server itself?
If you can't please share the Java Console for the server as well.
11-12-2012 03:24 AM
Hi Vinod Arya
Yes that is Windows Server.After I update the windows the topology is working server itself.But client PC is not work.
Thanks and Regards,
Shahul Hameed
